quote:Originally posted by Network_GuruHi Craig,It seems you can't edit any of the discovered properties in Orion.As a workaround, I suggest enabling SNMP to discover the device once & then remove the SNMP polling in Orion System Manager. It will then keep the discovered properties in the DB.
