Hi :
I´m looking for a way to know if a HP rack blade is On,
and if is possible get yours temperature.
Thanks in advance.
I'm not positive but I think HP Bladecenter can be monitored through the CPQRACK MIB:
http://www.oidview.com/mibs/232/CPQRACK-MIB.html
I´m receiving this message when I issue a snmpwalk command:
Unix>> /usr/local/bin/snmpwalk -c public -v2c xxx.xxx.xxx.xxx 1.3.6.1.4.1.232.22.2.3.1.2.1.1
SNMPv2-SMI::enterprises.232.22.2.3.1.2.1.1 = No Such Instance currently exists at this OID
Need I install CPQRACK-MIB in Orion ?
No you should be able to from unix or engineers toolset walk the mib and look and see if any of the cpqrack-mib oids work for HP Bladecenter. I don't have a bladecenter to test on... I just thought that like many other HP products that they would use the Compaq mibs.
