Hi all,
I have a clarification in solarwinds, ie each node and interfaces are considered as an separate object.
Regards,
CRK
Yes they are considered separate Network Objects. (Nodes, Interfaces and Volumes are the three types of Network Objects)
If you are trying to figure out how licensing works, the below post should help you.
Yann
