Hello,
Is-it possible to deactivate the ICMP checks of theses nodes because my Node status is down but still reachable by SNMP ?
Thanks in advance
Geolem,
This is not possible with Orion. It can only use ICMP for node status.If the node is reachable with SNMP, then there is no reason why you can't use ICMP as well.You may need to modify a Firewall rule, or resize the ICMP packet Orion sends for this to work.
Thanks for your answer.
