My assumption is that Orion already has a syslog server built in, right?
If so, when I try to connect on port 514, it does not connect...even doing a "telnet 127.0.0.1 514" right on the server does not work...
What am I missing??
Syslog is a UDP protocol - you can't test it with a TCP client like telnet.
Check the Windows Service Manager - is SolarWinds Syslog Service running?
Doh!...you're right...
Yes, the service is running...
You can run the Syslog Viewer app to see if Orion is receiving messges correctly.
Yes, loaded it on a server in the same subnet...but when trying to add the IP of the Orion server, it complains about not being able to resolve the DNS...I enter it anyway...and when I try a test, the event log tells me that it can't determine the syslog servers....
