When I go to look at installed agents, settings/all settings/Node and Group Management/Manage Agents, and look at my installed agents, they do not show a NetPath agent. Is this normal? The help system suggests that there should be one listed. If there should be one, how do I add it to an existing installed agent?
FYI, When trying out the default NetPath test, it is showing the Google is not replying.
