Is there a way we can check how many web console sessions running in NPM 10.4 or through the Orion Web server ? Also, are there any max / min count for concurrent web console sessions?
-- Prabu Ram
You could do a couple of things to see how many users are using the site at once. There is a perfmon counter you could monitor using SAM if you own a license for it. You could also send the IIS logs through something like Awstats to see the number of sessions and what not.
I think your minimum is 0. The maximum before an additional web server component needs to be added is said to be around 40 concurrent users.
Hope this helps.
Sohail Bhamani
Loop1 Systems
http://www.loop1systems.com
