Job Engine v2 fails to start after upgrade from NPM 12.3 to 12.4. anyone know a fix for this?
Does Windows Events give any clue on why it's failing? also is there any AV running that might be blocking it? You can also try uninstalling JEv2 and re-installing the installer is located in c:\programdata\solarwinds\installers
I would recommend starting with the following KBs
https://support.solarwinds.com/SuccessCenter/s/article/Job-Engine-V2-Service-stops-immediately
https://support.solarwinds.com/SuccessCenter/s/article/Reinstall-rebuild-Solarwinds-Job-Engine-v2
https://support.solarwinds.com/SuccessCenter/s/article/Solarwinds-Job-Engine-v2-and-Job-Scheduler-stops-intermittently-or-completely
https://support.solarwinds.com/SuccessCenter/s/article/Repair-a-failing-Job-Engine-Collector-and-Information-service-in-Orion-Platform
