Is there a way we can roll back / uninstall the NPM SP2
We started facing a lot of issues after installing SP2
There has to be a hotfix for these or a way to remove the SP2
Rajivbahl
You can rollback to a pre Service pack By running a repair on your Network Performance Monitor Install.This will return it to the original state
it was installed with .However i would really urge you to open a support ticket Immediately if your having issues like this. They may not be service pack related and we would like to find out what the actual issue is so that if there is a problem we can address is ASAP.
Thank You
We rolled back
We reinstalled
we installed 9.0 on a new machine with new Database the problem is there
Seems something is wrong in code.
FYI...a repair retuns u to 9.0 and no service pack. So if you want to be 9.0 SP1 you'll need to run the SP1 install.BB
