How can I add a resource to Orion's Web Interface that will allow users to remote console to Windows servers via mstsc ?
There is a link in the upper right on the NodeDetails page to a RemoteDesktop.asp page that will do that. Is that what you are looking for? Or do you want an RDP window within the NodeDetails page?
If you don't have toolset integration turned on (or you are using Firefox), you will not see that link. In that case try this:
