Hi Team,
Please advise.
We have 2 NPM with different version, with same device being monitored, but upon observation we get different bandwidth result on same device and same interface.
See below screenshot.
NPM 2011
NPM 2014
Is the polling interval the same also?
Yes. its the same
Were any changes made to the NPM 2014 system on Saturday the 5th? It looks like it was exactly the same until then and then it suddenly went down and stayed down. Looks like something fishy to me. I'd check the audit logs in Orion for any changes to custom bandwidth, interface settings, or web console settings. Also, I'd review the logs for the nightly Orion database maintenance as well as check and make sure the interface index for that interface matches in both nodes. I don't think this has to do with a difference between the older and newer version of Orion as much as it has to do with one of the systems started producing buggy results due to a problem that developed on Friday Night/Saturday Morning.
Oh yeah, an update those versions! Why oh why use old versions when the new ones are SO much better??
Thank you humejo, will check this further.
About the version, this site has different group with different SW purchase. Rich Client hohoho JOKE
I agree with this, it looks like something was changed on the 5th.
Good luck!
