I am having trouble searching for things such as "deny tcp src outside", or specific IP addresses in the Syslog viewer when Informational or Debug is selected in the message severity. I am constantly receiving a timeout error. If I unselect those two, it will find what I need, but very slowly. There are many times I am needing to search informational messages, but since it is timing out, I cannot do so. I only retain 10 days of data, and the actual database is less than 5 GB. What can I do to speed this up and fix the timeout issue?
We are using Syslog Viewer 9.5.0 and a separate SQL 2008 server with Dual Xeon 2.5Ghz and 8 GB ram. The Orion server and SQL server are connected via gigabit. Nothing else in Orion seems slow. The SQL server has very little usage.
Thanks!
Jason
