Is there a way to migrate SAM application monitors to NPM? Our environment has both SAM and NPM separate and we are manually moving everything over to the NPM side. I understand that the databases can not be combined.
We cannot migrate the complete configuration as you are already aware of that, but if its specific to template migration you can export and import it once you install SAM on your NPM instance.
Post import of template you will need to assign them to the devices/nodes.
Success Center
Import and export SAM templates
