Hi
I've 3 pertinent questions wicha are
-reading the details of the application it's possible to configure a tticket on the application
Using the remedy as tticket . how can i use this applicattion at same time with NMP,to report a tticket and get the database of remedy and synchronize qith the database of orion, ex:synchronize the table contacts
The other question is
Definig scratch propities with a field called lynks, and displaying then at the web view, how can i click at that field and open the hyperlink, without going through the edit coustom links
-a cores router has interfaces nd sub interfaces, at web view i only see the interfaces, by mib -oid 1.3.6.1.2.1.2.2.1.2 i see the subinterfaces associated, how can i display this information at web view
such as node-interfaces subinterfaces
Ty
Pampas
