This computes the average duration of a job from the job history tables, and computes a number representing how many times longer it is currently running than usual.
For example.
Job1 usually takes 30 minutes. If it takes 90 minutes, it will return 3.
It excludes jobs that take 30 minutes. In my particular environment, that filters out some noise.
It excludes the Ola Hallengren index maintenance job.
Type: Custom SQL Alert - Multiple Numeric Return
SQL Statement:
SELECT job.name AS 'jobName',
(DATEDIFF(SECOND,ja.start_execution_date,GetDate()) ) / (art.avgRunTime) AS TimesLonger
FROM msdb.dbo.sysjobs AS job
INNER JOIN
SELECT j.job_id,
AVG((run_duration / 10000) * 3600 + (run_duration / 100 % 100) * 60 + run_duration % 100) AS 'avgRunTime' /* convert HHMMSS to seconds */
FROM msdb.dbo.sysjobhistory jh
INNER JOIN msdb.dbo.sysjobs j
ON jh.job_id = j.job_id
WHERE step_id = 0 -- only grab our total run-time
AND run_status = 1 -- only grab successful executions
AND msdb.dbo.agent_datetime(run_date, run_time) >= DATEADD(DAY, -30, GETDATE())
GROUP BY j.job_id
) AS art
ON job.job_id = art.job_id
INNER JOIN msdb..sysjobactivity ja
ON ja.job_id = job.job_id
WHERE job.enabled = 1 /* do not display disabled jobs*/
AND NOT EXISTS
( /* make sure this is the most recent run*/
SELECT 1
FROM msdb..sysjobactivity new
WHERE new.job_id = ja.job_id
AND new.start_execution_date > ja.start_execution_date
AND ja.start_execution_date IS NOT NULL
AND ja.stop_execution_date IS NULL /* has not stopped */
AND (DATEDIFF(SECOND,ja.start_execution_date,GetDate())) > (art.avgRunTime )
AND ja.session_id = (SELECT TOP 1 session_id FROM msdb.dbo.syssessions ORDER BY agent_start_date DESC) /* Most recent run */
/* Greater than 30 minutes */
AND (DATEDIFF(SECOND,ja.start_execution_date,GetDate())) > 1800
AND job.Name <> 'Maintenance | IndexOptimize - USER_DATABASES'
Medium level - Min: 3 Max: 5
High level - Min: 5 Max: Empty
