Good afternoon folks,
I'm in the process of setting up a simple interface for some folks at my company. The sum of it is, I set up a simple home page for them with the couple maps they need. These maps give them access to only the nodes I want them to. They have a very very simplified menu bar that gives them the ability to go "home" and "logout". I'm fine with all this. The problem falls in between the header and menu bar. There is another menu bar that gives access to "application monitor" and "wireless networks" modules. I can't find where to turn this off.
Per usual, any help is apprecitated.
