Hi all,
I have searched around and not found a question quite like this. We have a good handful of new Juniper SRX devices that we are needed to monitor the SPU CPU and Memory utilization for, and trigger an alert if any of them are over a certain percentage. I have found the OID that has a table of the relevant information, 1.3.6.1.4.1.2636.3.39.1.12.1.1.1.4. For each of these SRX nodes, the amount of SPUs can vary, so naturally the table will as well.
I created a poller with the following settings:
- mib value type = raw value
- format = none
- snmp get type = I have tried "get next" and "get table"
- polling type = node
When I test this with the Orion Universal Device Poller application, it shows the full table of values. When I apply this to nodes and chart it, I am seeing the multiple readings but the column names are very strange as below. What would be the best method to make sense of this and generate alerts on a given SPU?
| | 20 |
| | 20 Trend |
| | 21 |
| | 21 Trend |
| | 4 |
| | 4 Trend |
| | 5 |
| | 5 Trend |
Thanks!
