I'm trying to add our temperature sensor Temperature@lert Wifi Edition Version 6.24 as a node (entity) but not having much luck. It will not pass the test or allow me to click next and gives me the error message Node does not respond with the supplied read/write community string
I'm going to manage node
Add Node
Enter the IP of the temperature node
Selecting Most Devices
Match the SNMP version, SNMP port and community string from the temperature monitor.
There is no read/write community string on the temperature monitor
I've tried this article Node does not respond with the supplied read/write community string
I have tested adding a different device without issue.
I can ping the temperature monitor from the solarwinds server.
Any help would be greatly appreciated.
