Is there a way to change the scale? Example : avg response time goes from 0 - 2500ms. Results in gauge always looking like it says 0ms.
Nevermind. They are hard coded ranges and I found the file to change.
OK, next question. Anyway to change the number of ticks used? 6 now, can I get more?
Which file did you change? I have been looking for this for a while...
Sent you an email
Which file are you working?
Sounds interesting
Could you also send me the file name? Thanks
I don't mess with these anymore but if you search \Inetpub\SolarWinds\Orion\NetPerfMon\Resources\NodeGauges for 2500 you should find files to change it in.
