Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Using Orion to monitor Enterprise NW
tdo_001
Hi All,
I'm looking for some network management tools to monitor ~300 routers and 2000 switches. I took a look at Orion it seems to lack some important features such as:
1. Flexibility: One can not add custom managed object.
2. Important statistics for popular technology: For example, there is no FECN, BECN, DE for Frame Relay circuit. There is no ATM information for ATM circuit.
3. Grouping devices into regions or management realms and provide statistics/reports per management group.
Any comments/corrections would be greatly appreciated
TD
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Some of the features you have mentioned are now supported in Version 7.0
- You can now add custom fields to the database to track circuit numbers, etc.
- Grouping objects in the Web interface is also now implemented.
As for the rest, Orion is only as good as the SNMP MIBs supported by
the device you want to monitor. There is no support for custom MIBs at this time however.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
