Hello
I need graphics the cpu and memory and filesystems in my solarwinds but only can graphics the stastics the lan interface, my SO is HP UX 11.23. How can graphics de cpu and memory and filesystems.
My problem is when add the server HP-UX 11.23 in the option the menu Orion System Manager Version 7, when i make click in "add node" , I write de ip the my host HP-UX and the community public (Option "Add Node or Interface to Monitor") . Then i Only see the network interface, but I can't see the CPU and memory y filesystem option. I probe with Tru64 and it work OK, my problem is only with the HP-UX
Petew
Pete,
It is the SNMP agent on the HP-UX systems. I would recommend changin the Net-SNMP which for most customers allows them to monitor the CPU, Memory, and file systems. You can find out more on Net-SNMP at http://net-snmp.sourceforge.net/
Cheers,
