I think there is an issue with the data export function.
If I look at the chart data then i can see each value is listed as B (bytes) or KB (Kilobytes). However, when you select "Raw Data" the raw values are exported but not converted either to B or KB. So you can't tell if 1234 is Bytes or KB.
Is there are workaround?
