I saw the release notes entry regarding this error on the APE, but I am actually getting it on the primary poller when I try to upgrade to 12.1. Are the instructions the same, or is there something else going on?
The article does specify APE's however as the root cause is with the licensing I suspect this issue could also apply to the primary pollers also. What does your license manager look like?
Bump? Please don't make me open up a ticket with Support, which will take a week for someone to get back to me.
Are there any more details you can share? Screen shot of error message, description of products and versions installed?
Looking at the release notes I do not see anything similar
NPM 12.1 Release Notes - SolarWinds Worldwide, LLC. Help and Support
This, which is in the release notes:
This is happening on my main poller, not my additional poller, upgrading from 12.0. I just need to know if the steps to resolve are the same, as the article only suggests that this happens on the APE.
In my experience, if you call to open the ticket instead of going online, you will get faster response.
