Newbie for latest VMAN and NTA 4.4 and i received a task to complete the solarwinds project which the modules involved is
1. NPM 250
2. NTA 250
3. VMAN 8
*all latest version
Customer requested for system requirement so i told them basically they need 3 servers
1x server NPM+NTA+VMAN
1x sql server
1x flowstorage
*declare as option A
But personally i think it should be okay if i create another with
1x sql server+flowstorage
*as a option B
reason why? VM is flexible to upgrade CPU & Memory
Orion server
CPU: 8 cores or better
RAM: 14 GB or better
Storage: 150 GB, 15,000 RPM
1 x 1 Gb dedicated NIC
Windows Server 2016 64-bit Standard or Datacenter Edition
SQL server+Flow Storage
Quad core processor or better
24 GB RAM or better
100 GB (or more) storage
SQL Server 2017, 2016 SP1 Standard or Enterprise Edition
just my concern, what will happen after 6 months because im not sure which option i should propose in documentation based on license purchased?
Thanks for advise and comments.
