I am trying to setup advanced alarms and you do not have a "does not contain" variable. This makes life difficult, so it's there a way I can use a varible in the name and " is not equal"?
For example a device name 01ABC12, can I use wild cards with "does not equal" such as %%ABC%%, or ??ABC*?
Please let me know as I cannot do properly with the current options.
Bob
