We just finished upgrading our whole environment to the latest versions last week. We are running: NPM 11.5.2, SAM 6.2.1, IPAM 4.3, NCM 7.4, WPM 2.2.0, SRM 6.1.11, NTA 3.11. Anyway, this morning I noticed that at the top of the Web Console that Database Maintenance is overdue.
When I click more details I get this (was originally showing 902 days):
We also dropped "Daily Details", "Wireless Detailed" and "Interface Detailed" from 1460 to 550 days. Once I saw this was overdue, I assumed our jump was too large, So I switched it to 1250, 200 days less than the original date we had set. I ran the maintenance and it completed. So now I set it to 950 days and the database maintenance app seems to be hung at "Beginning Maintenance for AlertHistory".
In the swdebugmaintenance.log file I am seeing this:
2015-06-22 07:38:25,554 [5] INFO SolarWinds.Data.DatabaseMaintenance.MaintenanceEngine - Beginning Maintenance for AlertHistory
*** Assembly SolarWinds.InformationService.Contract2, Version=2015.1.1.6134, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2015-06-22 07:39:48,650 [5] WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - Support! -- LONG RUNNING QUERY: 82637.919 ms: SELECT AlertObjectID FROM Orion.AlertObjects ao LEFT JOIN Orion.Nodes no ON ao.EntityUri=no.Uri WHERE no.Uri IS NULL AND ao.EntityType = 'Orion.Nodes' RETURN XML RAW
2015-06-22 07:42:58,559 [5] WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - Support! -- LONG RUNNING QUERY: 189894.0846 ms: SELECT AlertObjectID FROM Orion.AlertObjects ao LEFT JOIN Orion.Volumes no ON ao.EntityUri=no.Uri WHERE no.Uri IS NULL AND ao.EntityType = 'Orion.Volumes' RETURN XML RAW
2015-06-22 07:45:07,127 [5] WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - Support! -- LONG RUNNING QUERY: 128587.9398 ms: SELECT AlertObjectID FROM Orion.AlertObjects ao LEFT JOIN Orion.NPM.CustomPollerAssignmentOnNode no ON ao.EntityUri=no.Uri WHERE no.Uri IS NULL AND ao.EntityType = 'Orion.NPM.CustomPollerAssignmentOnNode' RETURN XML RAW
2015-06-22 07:46:30,323 [5] WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - Support! -- LONG RUNNING QUERY: 83192.0432 ms: SELECT AlertObjectID FROM Orion.AlertObjects ao LEFT JOIN Orion.APM.Component no ON ao.EntityUri=no.Uri WHERE no.Uri IS NULL AND ao.EntityType = 'Orion.APM.Component' RETURN XML RAW
I'm assuming it will eventually time out and continue on, but it is weird that at 1050 days it completes, but at 950 days it hangs.
Any ideas?
