I'm trying to determine if I can install a second polling engine while my primary polling engine is actively monitoring my environment. I would like clarification if during the second polling engine installation, will there be a gap in monitoring on my primary engine.
1) Do the Orion services need to be stopped on the primary poller before I install the software on my second polling engine?
2) Do the Orion services need to be stopped before I run the configuration wizard on my second polling engine?
Also, In the admin guide, it states
"Note:Additional Polling Engines only support data collection for EnergyWise, ESX Server, and wireless devices if the primary Orion NPM polling engine is running."
Does this mean I cannot reassign routers, switches, and physical servers to my second polling engine?
Thanks in advance.
