Thoughts?
I had to run the Integration install and do a repair for some reason. Oh, well, at least it is working again.
@pyro13g - we had exactly the same problem after installing NCM:
The Orion server cannot access the Orion NCM information service. The exact error was 'Object reference not set to an instance of an object.'
The rest of NPM and NCM seemed fine. Did a repair using the SolarWinds-Orion-NCM-v5.5.2-NPM-Integration.exe file and got the same error back.
Yes, after re-running the Integration exe everything worked as it should.
Thanks for confirming - guess I'll be raising a support ticket
@pyro13g - fyi I was given two fixes by SolarWinds support, your method being the first.
Should any one else experience this, and not get any joy from method 1 above, try:
Uninstall the integration via the remove option when running the NCM 5.5.2 integration from the installer and go through the configuration Wizard. -- Remove the folder, inetpub>solarwinds>Orion>NCM (Just the NCM folder please) --Open the NPM Web console, navigate to a nodes Detail pageClick on customize Page and remove any reference to NCM such as Download Configs, last XX config changes. --From the NPM Web console, click on the admin tab, Click on Manage views and remove any views that starts with NCM. reinstall the NCM Integration followed by the Configuration Wizard.
.....solution from Bill at SolarWinds support!
