Hi Folks,
I am currently in the evaluation stages of Orion NPM, and so far I like the platform. One of the issues I ran into some time back was the necessity of a realtime map view, projected on a screen in our NOC, so our staff could see network events the second they happen. Since we are a wireless provider, this is helpful in situations where a storm posses a threat to our network or an instance where a lot of events are occurring within a small amount of timeframe. I'd hate to compare it to this (don't laugh too hard), but similar to the WhatsUp console interface.
I am familiar with the MapMaker and Map displays on the Orion Web interface, but it lacked continual refresh of the content. Solarwinds support offered a code snippet for me to use, but it strobed the screen causing annoyance on a 80 inch screen (and potentially epileptic seizures)
In lieu of this, I created a javascript page of my own that performs a 2 second refresh without strobing the image, and I just thought I would share the wealth in case someone else out there is looking for this.
Caveats:
This was purely made to be a presentation screen only.
Download the attached file, unzip MapView2.asp, and place it in your NetPerfMon web directory (most likely C:\InetPub\SolarWinds\Orion\NetPerfMon)
Log into Orion NPM and go to Admin -> Web Console Settings. Change the Map Cache Timeout to 2 seconds.
Call your map with the MapView2.asp. (ie:
http://<your server>/NetPerfMon/MapView2.asp?Map=M:<mapname>)
Again, this will increase load on your server as you change the Map Cache Timeout, since your server will be regenerating images every 2 seconds. You can modify the refresh rate to whatever you'd like by changing the Map Cache Timeout in the admin screen, and the value of t in MapView2.asp. (line 34)
I hope this is useful to someone looking for this same idea implemented.
Mike
