We utilize a Load Balancer in front of our server farm and are having issues with this upgrade. Going directly to the server is fine, however using the VIP is causing the following error....
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
--- End of inner exception stack trace ---
at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead)
at System.Net.HttpWebRequest.GetResponse()
at ClassicSiteProxy.Login(HttpContext context, String username, String password)
at Login.DoLoginAction(String username, String password)
at Login.LoginButton_Click(Object sender, EventArgs e)
at System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e)
at System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument)
at System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
