I've run into a strange issue and am wondering if anybody has any ideas on where to look next. After installing SP1 for NPM 10, Firefox is unable to list the resources for any node using Firefox (v3.6.6). When attempting to do it, it shows the following:
Please wait while resources are being discovered...
Interfaces discovered: 2
Volumes discovered: 0
The number of interfaces discovered is always the first number it comes up with when it starts the discovery, but once it shows that number it doesn't change. The window tab shows that it is doing something and it says "Waiting for localhost..." in the status bar at the bottom. I have also found the following connections that are open:
C:\>netstat -a | grep -i localhost
TCP SSCL2DITA080CJC:1186 localhost:1187 ESTABLISHED
TCP SSCL2DITA080CJC:1187 localhost:1186 ESTABLISHED
TCP SSCL2DITA080CJC:1207 localhost:1208 ESTABLISHED
TCP SSCL2DITA080CJC:1208 localhost:1207 ESTABLISHED
TCP SSCL2DITA080CJC:1230 localhost:1235 ESTABLISHED
TCP SSCL2DITA080CJC:1235 localhost:1230 ESTABLISHED
TCP SSCL2DITA080CJC:1278 localhost:17779 FIN_WAIT_2
TCP SSCL2DITA080CJC:1322 localhost:17779 FIN_WAIT_2
TCP SSCL2DITA080CJC:1323 localhost:17779 FIN_WAIT_2
TCP SSCL2DITA080CJC:1328 localhost:17779 FIN_WAIT_2
TCP SSCL2DITA080CJC:1329 localhost:17779 ESTABLISHED
TCP SSCL2DITA080CJC:5152 localhost:1291 CLOSE_WAIT
TCP SSCL2DITA080CJC:17779 localhost:1278 CLOSE_WAIT
TCP SSCL2DITA080CJC:17779 localhost:1322 CLOSE_WAIT
TCP SSCL2DITA080CJC:17779 localhost:1323 CLOSE_WAIT
TCP SSCL2DITA080CJC:17779 localhost:1328 CLOSE_WAIT
TCP SSCL2DITA080CJC:17779 localhost:1329 ESTABLISHED
The number of connections on port 17779 increases each time I go to a different Orion web page. I know Orion uses 17777 for communication between servers, so I don't think port 17779 is a coincidence. I don't see this port being opened on any other machine when I connect to Orion. Using Internet Explorer from the same PC works fine, as well as using Firefox from a different PC. If I log onto an NPM v9.5 SP4 web page, with the same installation of Firefox that has a problem in NPM 10 SP1, I don't have any problems.
I have completely uninstalled Firefox (uninstall process then manually deleting directories & registry keys) and re-installed, but it still has the same behavior.
Does anybody have any ideas on where to look next?
Michael D. Jones
