I would like to monitor the performance of autos qos that has been applied to cisco 2960s switches. What mibs can I poll to get a better understanding of the performances of the queues? qua
Hi Steve_Warren,
Do you have a copy of engineers tool-set? If so you could use the MIB walk utility to view the MIB on the device and create a UnDP based on the OID you find, however Netflow Traffic Analyzer along with Voice & Network Quality manager may be more suitable to your needs. I would suggest downloading a trial both to see which meets your requirement as these products are specifically used in QoS monitoring
Tony Johnson
Loop1 Systems
www.loop1systems.com
Hi Tony,
I did use a MIB walker and tested a few OID's. I tried NTA before but it only works with routers that are configured to send the flows to NTA. It would be nice get a poller that shows the different queues and the drops packets for Cisco switches that support autoQoS
Steve,
Can you tell me which device and firmware you are running?
