Hi all.
Rather urgent problem here. I just upgraded to Orion 8.5, very smooth process, no errors. After that I upgraded NTA to 2.2, no errors there either. Orion website works fine, all subpages and functions working fine.
However when I click "Netflow Traffic Analysis" on the top of the Orion webpage I get the following error
System.Configuration.SettingsPropertyNotFoundException: The settings property 'TrafficAnalysis.NetFlowSummaryViewID' was not found. at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName) at System.Configuration.SettingsBase.get_Item(String propertyName) at System.Web.Profile.ProfileBase.GetInternal(String propertyName) at System.Web.Profile.ProfileBase.get_Item(String propertyName) at System.Web.Profile.ProfileBase.GetPropertyValue(String propertyName) at SolarWinds.Orion.Web.UI.OrionView.SelectView() at SolarWinds.Orion.Web.UI.OrionView.OnPreInit(EventArgs e) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
If I run the admin page and select Netflow summary page and preview it is presented OK but with a different path. The path on the Orion page is servername/.../SummaryView.aspx and in the admin preview netadm01/.../SummaryView.aspx
I need some quick fix to this.
Regards
Fredrik Hofgren
