Added a Cisco 5520 controller to SolarWinds. However, I cannot see the list of APs associated to this WLC.
Orion Platoform 2017.3.5 SP5, NPM 12.2
Any suggestions on how to get this resolved?
Hi Larry,
I used the THWACK Community Poller
And assigned my Node to it in List Resources, after which I was able to get all the WLC details as well as the APs associated to it.
Thanks,Rohan
Asking the obvious first, and assuming this was already done:
SNMP is enable on the WLC?
Your NPM server is allowed SNMP access?
SNMP polling is used for this WLC?
When you listed the resources, you checked "wireless"?
D
thanks for your help. I had already checked this info. Anyways, now I am able to see the AP list
what did you do to get it resolved?
thanks
larry
I recently had a similar situation where no Thin APs were showing while in Atlas, but showed on the summary page. I also noticed on the "Current Cisco Buffer Misses" widget values were "-2". I deleted and re-added the wireless controller which corrected the issue.
Frank
