Is there away to get a report of alerts generated and the times the alert manager actually sent an email to notify the customer. We have a requirement to show mean time to notify (MTTN) and are looking for such a report.
Create a custom SQL report in report writer..something like the below should give you what you want.. but it depends what alert actions you have defined. It would be nice for the report writer to allow you to browse and select tables/columns though!!
SELECT TOP (100) PERCENT dbo.AlertLog.ObjectName, dbo.AlertDefinitions.AlertName, dbo.AlertLog.LogDateTime, dbo.AlertLog.ActionType, dbo.AlertLog.Message, dbo.AlertLog.AlertDefID, dbo.AlertLog.ObjectType, dbo.AlertLog.ObjectID, dbo.Nodes.IP_Address, dbo.Nodes.Caption, dbo.Nodes.Location, CAST(dbo.ActionDefinitions.Target AS varchar) AS EmailTargetFROM dbo.ActionDefinitions INNER JOIN dbo.AlertDefinitions ON dbo.ActionDefinitions.AlertDefID = dbo.AlertDefinitions.AlertDefID INNER JOIN dbo.AlertLog INNER JOIN dbo.Nodes ON dbo.AlertLog.ObjectID = dbo.Nodes.NodeID ON dbo.AlertDefinitions.AlertDefID = dbo.AlertLog.AlertDefIDGROUP BY dbo.AlertLog.ObjectName, dbo.AlertDefinitions.AlertName, dbo.AlertLog.LogDateTime, dbo.AlertLog.ActionType, dbo.AlertLog.Message, dbo.AlertLog.AlertDefID, dbo.AlertLog.ObjectType, dbo.AlertLog.ObjectID, dbo.Nodes.IP_Address, dbo.Nodes.Caption, dbo.Nodes.Location, CAST(dbo.ActionDefinitions.Target AS varchar)HAVING (dbo.AlertLog.ActionType = 'email') AND (CAST(dbo.ActionDefinitions.Target AS varchar) <> '')ORDER BY dbo.AlertLog.LogDateTime DESC
sorry i will look into this again, this does not show MTTN!
Actually this helps. This combined with the alert log pretty much gives u what we need.
