I'm working on adding custom maps to our NPM page and adding certain OID's within it. I'm having issues getting some to display the values of the OID's.
Here is a screenshot of what it returns.
In Universal Device Poller setup you can see that it is only one value:
So why does the map show it as a tabular result?
I did a search in the forums and found this similar situation : UDP values for Network Atlas icons?
I applied the script listed in the last reply and it didn't fix my problem. Anyone have any other suggestions?
