I am trying to filter an "Interfaces with High Percent Usage" on the group name.
In the SQL I am using the following syntax:
Station = '${Name}'
(Station is a custom property)
While I don't get an error, I am not seeing any results either so I enabled SQL profiler and found the ${Name} macro was not being replaced with the group name which it does on the graph's subtitle using Station: ${Name}
Any ideas, am I trying to do something not supported or is there a way to incorporate macros into the SQL?
Pete.
