Here's the idea. I would like to create a Custom Properties that can differ under certain condition.
As an example, I would like to have a comment on shutdown port. So there i could set when the port status is Down or Shutdown there will be a certain value on the Custom Properties. But if its status is up, there should be other comments in the same Custom Properties.
