I've noticed in the events, that the NPM and APM service stops and starts at various times...in the EventViewer, I see NPM and APM stop then start, then stop then start...this last time, it did it three times.
Any ideas?
Is it doing this continually? Those two "services" are really running in one Windows Service - the Orion Module Engine. This explains why they tend to start and stop together. Running the config wizard will also cause them to be restarted.
If this is happening repeatedly with no apparent cause, you should probably track down why this is happening. Support can take a look at your log files and see if they find a cause.
I've done some research and it looks like they do this every 12 hours...I would guess that this is suppose to happen...
No, that's not supposed to happen.
Well, it does...should I open a case and do a Diag on the beast?
