Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Interface alert greater than 80% for 5 mins
jonchill
I can create an alert that triggers if an interface utilisation goes above 80% but what I want to do is set the alert so if an interface goes above 80% for 5 mins or longer then the alert will trigger. Alert suppresions as far as I can see does not give you this option.
Anyone done this any other way?
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Set the polling interval for that specific interface to 5 minutes.
-=Cheers=-
NG
rpereda
NG, I noticed that you recommended moving the polling cycle to every 5 minutes. Are you suggesting that the alert only goes off after the second notice. I was contemplating a way to set this alert. I was trying to think of a way to script the alert of send only after the second poll of that utilization.
Any suggestions?
Robert Pereda
Network_Guru
Robert,
I currently poll all my interfaces for utilization every 15 minutes.
If you are polling a very large number of interfaces, I think 5 minute intervals
would add a lot of extra load to your server and switches.
At 15 minute polling intervals, you don't get any spurious/intermittent data transfers setting of the alert. However your idea of writing a script to delay the alert only if 2 consecutive polling cycles are above a threshold, is a good one if you are monitoring at 5 minute intervals. Let me know if you get this going, as there are a few interfaces on our network that may benefit from something like this.
I'd also like to create a similar script for outage escalations and/or acknowledgements.
If a node gets paged out as down, the on-call person has 10 minutes to acknowledge the alert. If not, then it gets paged out to second level support, and so on.
The piece that's missing is being able to acknowledge an alert from the website.
-=Cheers=-
NG
rpereda
NG, The outage escalation sounds like something that a lot of us could use.
I have someone here that works wonders when it comes to scripting. In the event that we can get the alert delay to work, I will be sure to get you the information.
RP
rmines
Did anything ever come of the ideas in this thread?
Like many others, I'm interested in alert generation following a set period of high utilisation. Though setting the polling internal high is a kludgy way of achieving this after a fashion, it's not ideal.
If anyone has tackled this and got something working using scripts or some other mechanism, I'd be very interested in knowing more.
Network_Guru
I've not seen any further posts on this from forum members, but the SW gang is promising great new things for the alerting engine in V8. Let's hope this is one of them.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
