Hi everyone. I'm disapointed with 9.5 so far since we upgraded from 8.1. Let me tell you the problems I'm having right now so some of you might be able to help me.
1: Performance is really slow since we upgraded. I don't know if it's because 9.5 is using more resources but it' really below what we were used to with 8.1
2: On first login, it will not always display my main map at all. I have to click on the "Carte du réseau" (main network map) to view my map. When I do so, it will ask me to login again even though I just logged in a few seconds earlier. This was reported to support and they said to check the IIS settings on the server but we haven't found anything that could relate to this.
3: Some features were removed from Orion System Manager to move them to the Web console. The most obvious are the Poll, Rediscover, Unmanage and Validate SNMP buttons that are now greyed out. I understand the need to put those features in the web console but why remove them from the system manager? It's not like you have to code a new feature, you just have to leave it like it is! As you can probably tell, I'm not a big fan of the web console. If I prefer working with the system manager, please don't cripple it!
4: When you want to check stats on an interface for a certain time range, you have to make sure to select custom in the time period field even though you explicitly enter the details in the textboxes below. If you don't select custom, it will just pick the time period that was selected. It didn't work like this in 8.1, it just selected custom automatically once you entered the timeframe and hit enter or refresh.
5: The UI in network Atlas is not impressive at all for me. It used to work fine in 8.1 even if it wasn't pretty. Now I have to search like crazy to do the most mundane tasks. Of course I'll get used to it but I'm not sure they went in the right direction...
6: If I change the monitored interfaces in a node when I'm already in network Atlas, it won't update the list in the Atlas unless I close it and reload it again (which takes forever, btw). Once again, it was working fine in 8.1
7: The grouping options in network Atlas are great if you actually want some grouping. I don't! I'm used to the No Grouping view of my objects since it's easier for me (our nodes all start with XX where XX is the company number).
I think that's enough issues/problems for now, I just had to spill it out. If anyone has any idea how to help with those, let me know.
PS: I've always been a big fan of Orion, it's just sad that this version makes me disapointed like that...
