We are currently investigating this issue right now, we see this happening to in mutiple interfaces with different types of traffic, from high traffic to low traffic. We are currently working on trying to resolve this issue.
So far we have had nothing concreate that is causing this issue, We have changed NIC's, drivers, cables moved them to different modules on our 6500's and on some of the systems these things worked on other systems it has not.
We have a tac open with Cisco and are looking in the different hard versions of modules with the newer system, to see if there is any known issues with the type of cards, keep in mind that some of these line cards are coming up to 7 years old, and getting close to MTF, so possible RMA on the cards could fix our problems or not
Anyways my 2 cents, I will post more when we have more information
I'm not going to bite anyone's head off here, but try using the Forum Search function...
http://www.thwack.com/search/SearchResults.aspx?q=discards&s=9
I'm not going to bite anyone's head off here, but try using the Forum Search function... http://www.thwack.com/search/SearchResults.aspx?q=discards&s=9
Good answer John!I'm glad you said it & not me.....
I also want to open this up to suggestions or issues around high discards or errors on Cisco switches that have not yet been posted in this forum.
That might be hard to do Haley... This post reads almost Identical to the following post :-(
also to the Knowledge Base:
http://support.solarwinds.net/kbase/ProblemDetail.cfm?ID=406
