I'm trying to create a page\view which will have information on a different server in each column so I'm using the custom SQL filer but I keep getting Custom SQL filter is incorrectly formatted it appears the formatiing has changed but the show list of Volume properties you can plus out hasn't been updated?
I've read these but the links the top one points to longer exist.
https://thwack.solarwinds.com/thread/98248
https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/NPM_12_bug%3A_Custom_SQL_filter_is_incorrectly_formatted
and the 2nd one is a bug that has been fixed in the latest version but they do suggest that the table names have changed.
Does anyone know how to format this in NPM 12.0.1
I'm trying to do something like
VolumeID = 'xxxxx' or VolumeIndex = 'xxxxx'
Although I'm not sure how to find out what the volume index is either!
Thanks for any help,
worto.
