I screwed up my SNMP strings and had to reset them on all my switches. I used NCM to push the config change so that now they all have the correct matching SNMP strings, but now in NPM I have to go to "Edit Node Properties" and change all the SNMP strings. Is there any way to do a bulk change in NPM, so that I don't have to manually choose each device under "Node Management" and cut and paste the new SNMP strings one by one? They're all going to have the same strings, so I'd like to apply it to them all at once.
Thanks.
