I have been trying to get an alert for volume percent utilization over 30% to work. I have tried everything - moving the threshold down to 10%, even narrowing it down to one particular volume label, in which i KNOW (via SW) that it is utilizing
way more than that.
The test alert works fine, and i won't even get to the part where the percent variable seems to be off too. If a server has two local drives is it measuring both together for percentage? If it recognizes each volume as a separate measurable entity i can't imagine why?
Basically, am i doing something wrong? What are these crazy decimal point values for Volume percent used and disk space usage? I can't get these alarms to trigger!
