We have put in a new network with a bunch of redundancy. I'm having a hard time figuring out the best way to implement QoE. I want to see all traffic from both our HQ and remote sites hitting our servers. My end goal is when someone reports something is slow, I want to be able to look from say the remote site, across the WAN, through the HQ network down to the server and application to see what might have been causing the performance issue. In general we have an RDS farm and document management application that I would like to be able to see performance from different location and where the trouble spots might be.
We have several remote sites, lets say 20. Typical setup is a local switch, router and a few servers. I'm not really worried about performance between PCs and servers locally at each site right now. Most complaints are from accessing resources across the WAN. Management wants to start putting data back out locally at remote sites. I need some data to show that coming across the WAN is the issue, or is it SAN performance or VM performance back at HQ.
So, local site --> switch --> router -- WAN -- HQ router --> dual core 4500s --> dual Nexus switch (all servers hang off these).
All our server sit in one vlan. Our 4500s run VSS. Our Nexus 5Ks are linked together via Port Channel and we have an FEXs hanging off each one of those. Everything has redundant paths as you can see in the image below. Most our environment is Virtual. It seems I would want to look at traffic on the 4500s. If I was to say monitor/span the server vlan or a port, I would need to do that on both 4500s as traffic could be hitting either. Also then what sort of destination would/could I use? We have mulitple ESX hosts, so not sure how using one VM could see traffic on another ESX host.
Right now we just have the free licenses for QoE, so 11 SPAS and 1 NPAS. Other products we have are NPM, NTA, SAM and SRM. If need be, I could invoke the 30 day trial of QoE if we need more to do this. I want to make sure and not waste those 30 days trying to get the configuration right though. Also if this turns out to give us good data, I have something to take to management to maybe purchase more QoE license in the future if need be
