Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Beta Alerting Engine: Trigger and Reset actions
Grabowski
Has anybody been able to get Beta Alerting Engines Trigger and Reset actions to work other than the mail and the logging?
I've tried to launch local executables (and sending Netsends just to verify that the alerts are in fact triggered) but I cannot get it to work.
In the "old" Orion, we launch an executable that forwards alerts to our SMS/Textmessaging server with GSM modems. The string also includes custom properties for the GSM-SMS server to decide on which on-callperson should get the alert, so it's somewhat complicated:
cmd /S /C ""d:\Program Files\Zonith\NMSListenerClient1.3\bin\sendAlarm.bat" -t "${Time}:${Second}CET - ALERT: ${ApplicationName} is ${Status}"" -u ${Location_Code} -a ${relevance}
For test purposes, I also tried to launch a simple Notepad.exe as a trigger event, but that didn't work either.
Yesterday, I spoke with Solarwinds Support and was told that if i check "allow to interact with desktop" on the "LogOn" tab of the properties of the "Solarwinds Alerting Engine" service on my server this problem would be resolved, but unfortunately it wasn't
I would love to hear some details of any success stories you may have out there on this subject
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Currently using:
Cirrus Version 2.1 DL-500 Feb. 2006 (8.1.42)
Orion Application Monitor 7.8.82
Orion Web Engine Version 7.8.92
Orion NPM SLX 7.8.2 July 2005
Alert Manager 8.1.15
Find more posts tagged with
Accepted answers
All comments
dpezet
I can vouch for telephone paging using the NotePager Pro integration. I'll try launching a local executable and see what happens.
Don
dpezet
Just for a quick test I created a CMD file that executed:
dir c:\ > c:\test.txt
And set the new alert engine to run the CMD when a certain application was closed on one of my servers (we use the Application Monitor pack). I closed the application and a few minutes later I had a test.txt file on the SolarWinds server indicating proper execution. The added advantage of this test is that if an error did occur it would have been piped right into test.txt where I could read it.
You might want to try piping the output of your command into a text file to see what error it is returning.
Good luck,
Don
srazak
Using the Alerting Engine Beta, I cannot get any alerts triggered. I've followed the manual and set up some test alerts on both application failure and node failure. I do not get the email, nor do I see any posting in the "Active Alerts" tab. The events that I am monitoring do show up in the "Current Events" screen.
My existing alerts continue to work fine in Orion.
Please help as I would like to get the Application alerts working.
I am currently using March 2006 realeases of:
Orion SLX
Application Monitor
duncan_922
I just installed it today and it works pretty well. However I can trigger all alert actions (play a sound, flash color, text to speech, etc.) except sending e-mails. I am not using SMS though since our cel phones come with e-mail capability. Original alert e-mails from Orion work fine.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
