I have a remote location that has a router and two switches behind it. Today the router wan connection went down and Orion reported all three devices down and then later up.
I don't want to discuss event correlation (at this time).
I noticed that the down detection of the three devices took an elapsed 3:01 while the up detection only took 0:10.
Question: Does NCM switch to an aggressive polling method when nodes go down? That is the only reason I can think of that would result in the up detection being so close together in time.
Question: Why did the up alerts come in the reverse order? Shouldn't they be in the same order that they are generated?
| Alarm | Device | TimeStamp |
| down | loc-sw-1.example.com | 14:21:11 |
| down | loc-sw-2.example.com | 14:22:13 |
| down | loc-rtr.example.com | 14:24:12 |
| | elapsed time | 0:03:01 |
| up | loc-rtr.example.com | 15:05:35 |
| up | loc-sw-2.example.com | 15:05:38 |
| up | loc-sw-1.example.com | 15:05:45 |
| | elapsed time | 0:00:10 |
