Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Problem editing custom property via web interface
ajsburns
Hi all,
I have added a field on a node view to allow the editing of a particular custom property (basically to allow first line support to store the ticket number of calls against that node).
This works great under my login, but does not work for the login used by the helpdesk. What happens is that they can see the field & input data, but when they hit 'Update' it takes them back to their homepage & doesn't actually update the field.
The only pertinent difference between the accounts is that my account is allowed to customize the views & theirs isn't. As soon as I enable this functionality on their account, the update works. I do not want to give them the functionality as it would allow them to edit other fields I don't want them changing!
This would appear to me to be a bug, and I was wondering if anyone else had come across the same problem? Or could one of the Solarwinds guys comment?
Many thanks,
Al
Find more posts tagged with
Accepted answers
All comments
iunderwo
Editing a custom property is more or less akin to "customizing" a view.
In the current system of editing things, it's not a bug. SW will need to make an allowance for more granular editing for this to work as you'd like. That's going to require a fair bit of work on SW's part to accomplish since a simple yes/no flag would need to be replaced by a more complicated read/write access system.
// Ian Underwood - Network Engineering
// Boston Stock Exchange
Network_Guru
If you don't mind giving them rights to "clear events/alerts", then you could use the code in the following post:
www2.solarwinds.net/.../topic.asp
(about half way down)
This allows only users whose account is configured to allow event clearing to edit/update a custom property via the web page. You do not have to give them web page edit permissions.
....but watch out for this gotcha:
(again, about halfway down)
-=Cheers=-
NG
ajsburns
Thanks for the info, I'll give NG's suggestion a go when I have some time & let you know how I get on.
Al
ajsburns
Network Guru's suggestion is working well, many thanks for your excellent advice.
Al
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
