I need to write a report with the following items, and I am stuck.
I need a single line format for the time frame, right now it would start with daily, then go to weekly.
Something like:
Nodename, system uptime, system availability average, avg cpu, max cpu, min cpu, avg physical memory, max physical memory, min physical memory, avg virtual memory, min/max, avg disk i/o, min/max, user processor time avg compared to physical system time average, and so forth. Basically key server metrics on one line per node, and then I have to write others such as network uptime reports and such.
I am not a sql person and would rather grab a sql add-on easy report tool if report writer won't do this.
THANK YOU!!
